It is currently Fri Jul 18, 2025 5:21 pm
PostPosted: Thu Sep 06, 2007 3:54 pm
A while ago I posted a thread asking about some of the automatic Humidifier - Dehumidifier Combos available out there for a small shop. I remember the Danby 3 in 1 was one of the recommended models....
Anyone else is aware of any other models?
PostPosted: Thu Sep 06, 2007 4:12 pm
First name: Blain
City: Leander
Hey Peter.
Not sure if this is what you're looking for, but this says it's both so it might be an option for you as well.
I'll look a little more and let you know if I run across anything else.
Humidifier Dehumidifier
Blain
http://www.ullrichguitar.com
PostPosted: Thu Sep 06, 2007 4:22 pm
First name: Blain
City: Leander
A decent price on the Danby....
Danby
Blain
PostPosted: Thu Sep 06, 2007 4:28 pm
Thanks Blain...
I think the Danby may be the best bet!
PostPosted: Thu Sep 06, 2007 4:30 pm
First name: Blain
City: Leander
You're probably right.
And it doesn't look like there's a whole lot of options out there either. At least not from what I've seen.
Blain
PostPosted: Fri Sep 07, 2007 2:05 am
Yeah, that top one is a table-top type unit.   Seems pretty small.
The only thing about the Danby that bothered me was the small dehumidifier tank.  Only holds 6 liters.  For a 60 pint dehumidifier, thats emptying  nearly 5 times a day if the humidity is high.  I couldn't find out whether it had an option of draining directly.  I know you can buy little pumps to pump the water out if you want to.  A lot would depend on how much humidifying and dehumidifying you have to do.  I know I run my AC full out, and still have to run the dehumidifier to keep the shop in the 45 - 50 range.  It's sort of like beating a dead horse.  The dehumidifier raises the temp about 8* and the AC lowers it a little more, but if it's 90+ outside, it's a nice dry 80 - 85 in the shop.
PostPosted: Fri Sep 07, 2007 3:15 am
Would not take much to to add a small bulkhead fitting to the tank and pipe it out some where
PostPosted: Fri Sep 07, 2007 5:29 am
I have just started looking at humidifiers and dehumidifiers for the shop i
am setting up. I didn't even realize they sold the all-in-one units. Thanks
for the heads-up on these.
